Hello Guest it is June 09, 2026, 10:01:34 AM
Author Topic: Mastercam X Lathe Post processor  (Read 8842 times)
« on: February 06, 2007, 03:51:38 PM »
Has anyone used Chris Krstanovics V9 post processor in mastercam X. It behaving very oddly as for roughing work it is fine, however when I put a finish path in, all the arcs are in the wrong direction (but not in the roughing pass!!!). Anyone else had this problem or got a post that wrosk?
Re: Mastercam X Lathe Post processor
« Reply #1 on: July 25, 2014, 11:47:58 AM »
Beside the arcs in the wrong direction they seem to me like if they are the other or missing side of the circumference!
Sadly so far I have not been able to use not even a single of the G-Codes generated by Master-cam, it is most that obvious that when I run all my tool paths in the simulation on the computer with master cam every thing works perfectly! but when ever I transfer those G-Codes to my late computer! all hell brake loose! if you have any kind of success please share it with us! I hope that I can hear soon from some one here!
