Hello Guest it is March 29, 2024, 12:54:58 AM
Author Topic: G00 problem with mach3  (Read 5596 times)
« on: March 11, 2013, 04:55:58 AM »
I have a problem with G00 Command in Mach3 with DSPMC. For example i give G00 Z1, The Machine goes
0,62 and on the DRO i can see 0,62 - but i wanted to have 1 mm. Nevermind what Speed. This is
always
when I use G00. If i give G00 Z5 then machine goes to 4,62 mm. It seems that machine is about 0,1
seconds without PID loop and in this time Z travels down 0,38mm.
If I drive axis from DSPMC plugin gonfig it works fine.
If I reset Z counters from plugin control, VITAL DSPMC status Z drops every time 0,38mm.
I tried to push Y axis while giving g00X0, same happens to Y axis it will lose about 0,1mm
every g00.
It does not matter if I give G00X,Y or Z.
My config is:
DSPMC  7762S
Mach3 R3.043.066
DSPMC with latest firmware from vitalsystems website and mach3 plugin from same file.
Omron U-series servos with ballscrew from IA corporation.
Servos is analog input and speed mode.
Pulses 2000/revolution.
Re: G00 problem with mach3
« Reply #1 on: March 17, 2013, 11:43:05 AM »
Problem solved.
Problem was I max error.
So if I put something else than 0 to I max error machine works strange with G00 command.
