Hello
Guest
it is
March 28, 2024, 04:35:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
ESS and Mach Lathe, which SW-Version?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: ESS and Mach Lathe, which SW-Version? (Read 7823 times)
TomS
17
on:
March 09, 2013, 10:50:57 AM »
Hello,
at many posts there are recommended Version 057 for lathe, but this will not with ESS, if i use the ESS, it is nessesary to use upper 062.
What is a good working version with ESS and lathe?
Best regards,
Tom
Logged
Carnoustie, Scotland
Re: ESS and Mach Lathe, which SW-Version?
Reply #1 on:
March 09, 2013, 05:18:49 PM »
I use 057 on the big lathe and it has an ESS, however I use an older plugin for the ESS, 10a I think. If you use one of the newer plugins then you will likely need 062 or newer. I think the problems with Turn started in 066 but cant be sure as I dont think I had anything newer than 057, except my trials of 066/7
Logged
TomS
17
Reply #2 on:
March 10, 2013, 05:38:55 AM »
Hello Hood,
thanks for your reply. Where i can get this early plugin? On the Warp9 site, there is the earlist Version 10eb1a (and there are big Problems with MPGs)
Best regards,
Tom
Logged
Reply #3 on:
March 10, 2013, 06:18:00 AM »
I posted it here
http://www.machsupport.com/forum/index.php/topic,21036.msg167619.html#msg167619
Logged
Print
Pages:
1
Go Up
« previous
next »
