Hello Guest it is April 20, 2024, 01:30:32 AM
Author Topic: Button Script to search through active Gcode File for NEXT Tool change  (Read 19209 times)
Hi ALL, This is a button script to allow you to search through a loaded Gcode file. It advances to the next M6 it finds in the current file. If no file is loaded then it errors OUT and ends.
(;-)TP
'Macro for  GcodeFile string search
Dim sLine As String
Dim i As Long
Dim lFoundLine As Long
Fname = FileName
If Fname = "No FIle Loaded." Then
MsgBox" There is NO File Currently Loaded in Mach3"
End
Else
Open FIlename For Input As #1
Do Until EOF(1)
  lFoundLine = lFoundLine + 1
  Line Input #1, sLine
  If InStr(1, sLine, "M06") > 0 And lfoundline > GetDro(16) Then
    Exit Do
  End If
Loop
Close #1
Nline = (lfoundline -1)
MsgBox""&Nline
Setdro(16,Nline)
End If
End
Might want to add an alternative or "M6" search also.
You sure are working hard on your Florida winter retreat.
Have fun.
Hey Terry,
Thanks for the code!
Doing for Turn, what if we OR gated the following in the If statement: "T0" OR "T1" OR "T2". True, not an elegant way, but it will do what's needed. And I don't have tools on the lathe past 29. If I had I could just add another one to the OR: "T3" and so on...
Good Idea about teh M06 Most use M6 just change out the text to M6
For turn just change out the M6 to the "T" , or  "T?? yes it could pickup the letters in a (message) but just push the button again to advance to the next T??.
Not really a retreat only lived here for 59 years so far(;-)
Sorry I thought you lived in the northeast
Now that is unless you have messages with a 'T' in the comment.   ;)
« Last Edit: March 10, 2013, 08:25:55 PM by Ya-Nvr-No »
I am working on fixing the "T" deal but I don't have a clue yet as HOW to ignore strings inside the ( ) . Some things are obvious that one is not(;-).
At least to my little pea brain, (;-) TP
Use a flag that when you see a "(" you set the flag to 1 keep searching until you see a")" reset the flag to 0. Than your back to looking for a "T"
(;-) IF you can fix it please DO.  It may take me DAYS to figure out HOW to make it work as I am not a programmer but a code assembler(;-).
There is also another error in the code I just saw.
Should read as
 If InStr(1, sLine, "M06") > 0 And lfoundline > (GetDro(16)+1) Then
Other wise it will not search beyond the same line number. It just repeats the same line number.
See... you can do it, you have been a machine at pumping out useful code. Just need to push your talents a little, always been fun for me to learn new things. I think your like that too.
'gives you the idea.
Do Until EOF(1)
  If InStr(1, sLine, "(") > 0 And lfoundline > GetDro(16)+1 Then
    flag=1
  End If
  If flag=0 Then
    If InStr(1, sLine, "T") > 0 And lfoundline > GetDro(16)+1 Then
      Exit Do
     End If
  End If
  flag=0
Loop
