Hello
Guest
it is
April 20, 2024, 07:12:12 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Delay in G-code - can't seem to eliminate it
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Delay in G-code - can't seem to eliminate it (Read 7558 times)
Chaoticone
5,624
Precision Chaos
Re: Delay in G-code - can't seem to eliminate it
Reply #10 on:
March 07, 2013, 09:44:37 AM »
Post up your XML and g code and I will take a look in a little bit. It may be a few hours as I'm going to a fab shop to have some pieces bent.
Logged
If you could see the things I have in my head, you would be laughing too.
shobley
25
Reply #11 on:
March 07, 2013, 09:56:52 AM »
The GCode I posted at the start, the XML I'm unsure of, is this the configuration file for Mach3?
Logged
Chaoticone
5,624
Precision Chaos
Reply #12 on:
March 07, 2013, 10:05:42 AM »
Yes, it will be in the C:/Mach3 folder and will have the .xml file extension. There may be several so be sure to choose the one you use on your machine and when you upload it make sure it has a unique name.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
