Hello Guest it is April 23, 2024, 08:50:48 PM
Author Topic: Whoops: Parameters not working  (Read 5821 times)
« on: March 04, 2013, 05:19:40 PM »
Ron,
The attached .JOB file shows two operations. I am doing a .625 hole on the top and bottom faces of a 1" sq tube using a line of holes using the circle function. The first hole operation has Ztop of 0, Zdepth of -0.130. The second operation is supposed to have Ztop of -0.875 and a Zdepth of -1.100. The operations list seem fine, but the GCode is not working. Ztop on the second cut is still 0.0 instead of what I specified.
(***New File Started***)
(created by NFS Mill, V4)
(New File Started 03/03/13 21:50:20)
(posted for Aluminum )
(Strategy: Equal )
(Rapid height: 0.5000  Clearance height: 0.0100 )
G98 G80 G17 G90 G54 G64
G20 G90
(***New Tool Selected***)
(ToolNum: 11  Diameter: 0.3750  )
(Feed: 24.0000  SFM: 850.0000  Plunge: 12.0000  ChipLoad: 0.0375  )
M9
M5
M06 T11 ()
G43 H11
M03 S5100
M8
(***Line of Holes***)
(Xstart:  0.5000  Ystart: -0.5000  Num: 01  Inc: 0.8750  )
(Angle:  0.0000  Depth: -0.1300  Peck: 0.0625  )
G00 Z0.5000
(***Cut Circle***)
(Xorign: 0.5000  Yorign: -0.5000  Dia: 0.6250  InOut: 00 Dir: 00  )
(Ztop: 0.0000  Zdepth: -0.1300  Zstep: 0.0433 )
(will make  3.0000  cuts of:  0.0433 )
X0.6250 Y-0.5000
Z0.0100
G01 Z0.0000 F12.0
G02 X0.3750 Z-0.0433 I-0.1250
G03 X0.6250 I0.1250
G02 X0.3750 I-0.1250 F24.0
X0.6250 I0.1250
G01 F12.0
G02 X0.3750 Z-0.0867 I-0.1250
[Edited out operations]
G01 F12.0
G02 X0.3750 Z-0.1300 I-0.1250
G03 X0.6250 I0.1250
X0.6250 I0.1250
G00 Z0.5000
(Angle:  0.0000  Depth: -1.1000  Peck: 0.0625  )
G00 Z0.5000
(***Cut Circle***)
(Ztop: 0.0000  Zdepth: -1.1000  Zstep: 0.0611 )
X0.6250 Y-0.5000
Z0.0100
G01 Z0.0000 F12.0
G02 X0.3750 Z-0.0611 I-0.1250
G03 X0.6250 I0.1250
X0.6250 I0.1250
G01 F12.0
G02 X0.3750 Z-0.1222 I-0.1250
[edited out operations]
G01 F12.0
G02 X0.3750 Z-1.1000 I-0.1250
G03 X0.6250 I0.1250
X0.6250 I0.1250
G00 Z0.5000
M09
M05
M30 (end of file)
Re: Whoops: Parameters not working
« Reply #1 on: March 04, 2013, 05:39:06 PM »
That is NOT what your operations show. (;-)  Both have a Ztop of 0.000.
Just a thought, (;-) TP
« Reply #2 on: March 04, 2013, 05:47:46 PM »
You mean this operation? Hence the bug report.
« Last Edit: March 04, 2013, 05:50:14 PM by kevinro »
« Reply #3 on: March 04, 2013, 07:09:36 PM »
Ok, I just found a bug. We added Ztop but forgot to add it to the Job string. Its in the internal data struct but not fully added to the code.
thanks
Ok, that was an easy fix. Brian will be updating the installer file tomorrow.
I checked and it was wrong on all 4 hole operations.. All fixed now
« Last Edit: March 04, 2013, 08:23:31 PM by Ron Ginger »
« Reply #4 on: March 04, 2013, 07:41:18 PM »
thanks
Yay! I will watch for it.
Kevin
« Reply #5 on: March 04, 2013, 08:34:32 PM »
I just looked at your job file and it shows Ztop 0.000 for both operations ?????
« Reply #6 on: March 04, 2013, 09:12:51 PM »
I just looked at your job file and it shows Ztop 0.000 for both operations Huh??
yes, that was the problem. Ztop was not being saved in the job file, and it was not being passed to the gcode generator.  The same thing was happening to all 4 hole operations.
There is a bit of a problem on those ops. The Drill cycles do not have a parameter for Ztop, they always start at Z=0 Only the circle and circle pocket can have a non zero top.
« Reply #7 on: March 04, 2013, 10:13:34 PM »
Ron a Drill cycle can have Ztop anywhere +/- it does not have to start at Z0 The ztop is defined before the Cycle call and retracts back to where ever you want with the R value.
The G98/99 also control the R values so you can have Ztop defined at teh start AND the G98 will retract back to that point in lue of the R value.
NOW IF you do not define the Rvalue then Ztop will be Z0 and the retract will be Z0 which is NOT always correctly  applied as to G98/99 mode
« Last Edit: March 04, 2013, 10:28:35 PM by BR549 »
« Reply #8 on: March 05, 2013, 09:05:55 AM »
Ok, we already had that in the code R is set as wxT(" R ") + gcFmt(a.Ztop + jobS.Clear)
