Hello
Guest
it is
April 18, 2024, 06:54:49 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Waterjet/lookahead/accelerate-slowdown
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Waterjet/lookahead/accelerate-slowdown (Read 5174 times)
cheeky
11
on:
February 05, 2007, 03:28:35 PM »
How and where do I apply settings to make the feedrate slow down before a curve and speed back up after it? Can I adjust these settings?
Peter
Logged
chad
361
When the going gets weird, the weird turn pro.
Re: Waterjet/lookahead/accelerate-slowdown
Reply #1 on:
February 09, 2007, 01:18:37 PM »
In mach click on the settings tab. Look for "CV Fedrate" this is the speed mach will use if the angular limit is reached. You can set at what angle the alternate speed kicks in...
Chad
Logged
ger21
6,295
Reply #2 on:
February 09, 2007, 03:06:42 PM »
If by curve you mean G2/G3, then just change the feedrate on those lines of code.
Logged
cheeky
11
Reply #3 on:
February 09, 2007, 03:38:56 PM »
Thanks Ger21 and Chad. I cant do gcode so I dont know what youre talking about.(Spolit by Sheetcam)
Chad? where is the "second" speed you are referring to.
I worked on waterjet machines and I could specify the rate it slows down and speeds up in mm/min or whatever.
tnx again
Logged
chad
361
Reply #4 on:
February 09, 2007, 11:45:02 PM »
Sorry i didn't explain that very well.
The "CV feedrate" is the speed it will slow down to.
The "angular limit" is what angle and above is used to set the slower feedrate.
Chad
Logged
cheeky
11
Reply #5 on:
February 10, 2007, 12:01:23 AM »
Thank you Chad.
Peter
Logged
chad
361
Reply #6 on:
February 10, 2007, 12:19:49 AM »
No problem
cHAD
Logged
Print
Pages:
1
Go Up
« previous
next »
