Hello Guest it is April 24, 2024, 06:03:39 PM
Author Topic: Digitize wizard crash/does not wirte file/machine stop.  (Read 1889 times)
« on: March 04, 2013, 08:32:12 AM »
Hi.
I've recently set up my CNC for probing.
I am using the digitize wizard but getting a couple of issues.
The program runs, but crashes at random intervals and does not write the .txt file.
It records very small areas (10x10mm) but not anything roughly larger than 50x50mm.
The code then becomes corrupt and will not run again.
I have looked through the forums but can not find any solutions so far (similar issues but haven't found the solution).
I have tried to install 'probing.dll' which does not appear in my wizard or plugin setup.
Thanks in advance for any help on this!
Re: Digitize wizard crash/does not wirte file/machine stop.
« Reply #1 on: March 04, 2013, 12:54:44 PM »
Are you using the Wizard OR the PLUGIN ?
