Hello Guest it is April 24, 2024, 06:16:34 PM
Author Topic: Slotting Through Wizard  (Read 6344 times)
« on: March 03, 2013, 11:29:16 AM »
I can't seem to get the slotting through wizard to work. When I activate it, the machine seems to wander all over the place.
There are several things winth this Wizard I don't understand:
1) There is no setting for English or Metric Units
2) There is no setting for spindle speed
3) The windows for the numbers are too small and the numbers can get cut off.
4) there ate two settings, wall thickness and the Xo  and Yo that seem to be redundant.
Is there something I am missing?
Peter McKelvey
Re: Slotting Through Wizard
« Reply #1 on: March 03, 2013, 12:14:54 PM »
I do not understand which wizard you are referring to. I suspect it must be one of the user submitted wizards, which are not part of the Newfangled set and are not supported. If you can better identify which wizard I may be able to help.
« Reply #2 on: March 05, 2013, 11:05:46 AM »
The wizard came with Mach 3 on my machine.  It is called "Slot Through" and the description says "slotting through  X and Y". It was submitted by someone named Kiran.
« Reply #3 on: March 05, 2013, 12:56:15 PM »
1) You are correct, but just use appropriate numbers and add the G20 or G21 before you run the code.
2) Again, you will have to add that yourself.
3)You must be using metric values. I tried an English sample and the numbers fit ok.
4)Xo and Yo refer to the corner of the stock. The wall thickness lets you cut a slot of less than the whole stock wide.
I tried an example and it seemed to generate good code. Your comment
doesn't tell me enough to understand what you see happening.
These are user submitted, unsupported wizards. Kirin did a lot of them when the wizard capability was first added, but I have not seen his name on the list for a while. Maybe he has other interests now. Kirin did good work, and I'm sure the wizard works, but it certainly could use some additional features.
You can use the screen editor and fix these wizards any way you want to if you are willing to learn how to use the tools.
The Newfangled Set costs $50, but it is much more complete and is supported. There is not exactly a slot through operation but the surface or rectangular pocket would do the job.
« Last Edit: March 05, 2013, 12:58:00 PM by Ron Ginger »
« Reply #4 on: March 06, 2013, 08:29:23 AM »
Thanks for the help.  I will try again.  I am new to this.  I bought a license for Mach 3.  Are the New fangled wizards in addition to this,and do I download them from the same site?
« Reply #5 on: March 06, 2013, 04:16:42 PM »
The Newfangled wizards are extra $50. They are built into the mach install kit, but for some reason not always the latest version. They can be loaded from this forum, see the topic for 'latest version'
