Hello Guest it is April 26, 2024, 05:17:33 AM
Author Topic: Feed override for all axis motion commands  (Read 7259 times)
Offline MEA
  •  5 5
« on: February 27, 2013, 02:26:52 PM »
The implemented feed override is not working, so far I found out, during axis referencing or G31 probing.
With a feed override to zero before stop, I get a "smooth" stop. There are reasons to stop, not estop, during a movement.
I know, during a G-Code file run it is possible to do a smooth stop with the "feed hold" button even if the time to stop is not predictable.
Daniel
Re: Feed override for all axis motion commands
« Reply #1 on: March 14, 2013, 09:50:48 PM »
You can do what I think you’re talking about by pressing the Escape key while a G31 X4 F12 command is being executed. It also works in a probe macro with a G31. The axis move slows down and stops, like you pressed the “Feed Hold” in a G1 command move.
