Hello
Guest
it is
April 26, 2024, 11:17:43 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
LazyTurn
LT gcode diameter larger than needed
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: LT gcode diameter larger than needed (Read 19272 times)
moskit
6
on:
February 01, 2013, 03:39:31 PM »
Guys, any one had something like this?? i post gcode with 26mm but the gcode ends 26.400
Z-36.6834 X25.6382
Z-37.7449 X25.8082
Z-37.7696 X25.8120
Z-38.8344 X25.9602
Z-38.8591 X25.9635
Z-39.9515 X26.0926
Z-41.0464 X26.1991
Z-42.1431 X26.2832
Z-43.2414 X26.3446
Z-44.3407 X26.3835
Z-45.4406 X26.3998
Z-80.0000 X26.4000
Z-80.0000 X26.4000
Z-80.0000 X26.4000
Thanks for any advice
Last Edit: February 01, 2013, 03:41:08 PM by moskit
Logged
Re: LT gcode diameter larger than needed
Reply #1 on:
February 01, 2013, 04:49:21 PM »
Post the dxf file. Provide a pic of the tool definitions that you are using.
Logged
Machtank
67
Reply #2 on:
April 28, 2013, 01:14:15 AM »
Yes ! I get that too.
It seems to be mainly influenced by the Tool radius specified. (finish cut settings also have a slight effect)
Logged
mohamedhelmi
14
Reply #3 on:
November 15, 2013, 01:09:38 AM »
I have same problem.
what that means ? and what is the solution ?
Logged
Reply #4 on:
November 15, 2013, 04:56:31 AM »
Logged
mohamedhelmi
14
Reply #5 on:
November 15, 2013, 05:00:56 PM »
Dear Rich,
please check attachment, and for info this broblem happen for all tests that I do.
when transferring from AUTOCAD to LT all ok. but when posting from LT to Mach 3 the Diameter of the ROUGH path looks clearly more bigger than the FINE path.
Logged
Reply #6 on:
November 15, 2013, 09:12:53 PM »
Can you save and then post your drawing as a version 12 dxf?
I can't open your drawing.
Logged
mohamedhelmi
14
Reply #7 on:
November 16, 2013, 02:00:05 AM »
dear Rich,
I dont find extention .12DXF
I have DXF (autocad 2010,2007, 2004, 2000, 14 )
does .DXF means (DXF autocad 12) ?
Logged
Reply #8 on:
November 16, 2013, 05:45:51 AM »
I use Autocad 2007. It will not read newer versions.
Save the file as shown in the pic.
Logged
mohamedhelmi
14
Reply #9 on:
November 16, 2013, 06:58:27 AM »
OK Rick,
I'll do it asap (because I'm at work right now)
thanks
Logged
Print
Pages:
1
2
Go Up
« previous
next »
