Hello
Guest
it is
April 23, 2024, 07:50:29 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Third party software and hardware support forums.
SmoothStepper USB
(Moderator:
Warp9TD
Problem with ESS install
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problem with ESS install (Read 4363 times)
strud
14
on:
January 28, 2013, 01:57:29 AM »
In the process of setting up an ESS to test on an XP system and am having issues connecting to it.
Neither connection from Mach3 with the plugin or using the Configurator tool is working.
I used wireshark to see what is going on and it seems that there is a path problem of some form since after the Configurator responds to the Boot request with a 'Boot Reply' it seems it is looking for "d:\a.bin" which does not exist.
Screen capture attached.
No firewall turned on
PC IP address fixed at : 10.9.9.1
PC Hardware : Fairly old IBM laptop (Thinkpad)
Thoughts ?
CS
Logged
Jeff_Birt
1,107
Re: Problem with ESS install
Reply #1 on:
January 29, 2013, 11:36:46 AM »
With an older network adapter you will likely need a crossover type Ethernet cable. About the time Gigbit ports came out most Ethernet adapters had the auto crossover capability built in.
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
strud
14
Reply #2 on:
May 07, 2013, 07:33:05 AM »
Just to finish off this thread, the problems were resolved on a much newer set of hardware, so it seems the very old ethernet hardware was likely the problem.
CS
Logged
Print
Pages:
1
Go Up
« previous
next »
