Hello Guest it is April 25, 2024, 12:58:14 AM
Author Topic: Simple xml  (Read 3254 times)
Simple xml
« on: January 22, 2013, 04:25:17 PM »
Let's assume I have everything downloaded and installed.I have a g540 which is working fine with a parallel cable. I have a SS which is blinking it's little red led heart out. Does someone have a xml file which would just let me jog the axes? No look out for or make sure you or anything else. Just a xml file. PLEASE
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Simple xml
« Reply #1 on: January 22, 2013, 07:26:00 PM »
If you have the G540 working with the parallel port than you have the XML you need. You just need to tell Mach to use the SmoothStepper instead of the the parallel port. Take a look at http://www.soigeneris.com/Document/Warp9/Installing_and_Configuring_the_SmoothStepper.pdf on page 4. It will tell you have to change the motion device in Mach3.
Happy machining , Jeff Birt
Re: Simple xml
« Reply #2 on: January 22, 2013, 08:38:46 PM »
Works. Thanks. Nice website.
