Hello Guest it is April 27, 2024, 12:39:08 AM
Author Topic: Turn Probing Wizard  (Read 4461 times)
Turn Probing Wizard
« on: January 14, 2013, 11:16:41 AM »
Here is a Wizard for probing in TURN. Fill in the required data and it will probe the part. This wizard does NOT create Gcode and return to mach3 IT probes directly from the Wizard.
As always Test it before you use it.  Iit has new CB code to drive the probing routine.
Unzip the file into the TurnAddons directory.
