Hello Guest it is March 29, 2024, 02:38:11 AM
Author Topic: Mastercam X4 Machine Def file  (Read 5275 times)
« on: January 07, 2013, 10:47:17 AM »
Hi Guys,
I looking for a little help.
I have converted a small 11x29 lathe to CNC. It has a QCTP on the front.
I am using Mach 3 for the controller.
I am looking for a Machine definition file for Mastercam X4 that would match up to my lathe.
I also need to know which post-processor to select that matches up to Mach 3's capabilities.
Any help in pointing me in the right direction would be appreciated.
Dirk
Re: Mastercam X4 Machine Def file
« Reply #1 on: January 07, 2013, 12:20:44 PM »
Hello, Dirk,
MasterCam themselves are the ones to ask, as it's the software companies responsibility to provide you with a proper post processor for their CAM program, and any other info for your specific machine.
That's why they get the big bucks!  ;)
« Reply #2 on: January 07, 2013, 05:44:46 PM »
Hi Dave,
Since I do not have a specific machine to give them, It would be difficult to get them to provide anything.
It is just a converted 2 axis manual lathe with a QCTP and Mach 3.
I'm sure someone is using that combination.
I'm pulling my hair out trying to figure this thing out. LOL.
Dirk
« Reply #3 on: January 07, 2013, 08:19:31 PM »
Well if it's that simple then they should have no problem supplying you with a post processor as I'm sure they have one set up for Mach 3?
Have you asked them?
« Reply #4 on: January 08, 2013, 07:56:30 AM »
Here is a link of what MC has available.
http://www.mastercam.com/teachersstudents/educationaldownloads/Posts/Default.aspx
There is a file that matches but it's for version X5. I tried to load that file into X4 and it won't load. I also tried the post file  LDMaster off of emastercam.com.
Does anyone know of a way to convert an X5 machine definition file from X5 to X4?
Dirk
« Reply #5 on: January 08, 2013, 10:57:09 AM »
Not sure why you aren't using what you paid for in their customer support. That is part of the high price for this software and I would certainly be taking advantage of that.
I'll let you choose how you want to handle it.
« Reply #6 on: January 08, 2013, 01:16:39 PM »
HI Dave,
Thanks for your concern. I purchased this software from a departed friends wife. So I do not have this software under maintenance and can not ask MC support anything.
Dirk
« Reply #7 on: January 08, 2013, 05:49:25 PM »
SURE you can ask. The worst thing that can happen is they say no.
