Hello Guest it is April 26, 2024, 03:07:20 PM
Author Topic: Probing Wizard  (Read 20640 times)
Probing Wizard
« on: January 05, 2013, 06:09:11 PM »
Cleaning up some old macros and making a new Probing wizard.
Re: Probing Wizard
« Reply #1 on: January 05, 2013, 06:41:08 PM »
You are a pain in the arse TP, looks like I will have to eventually hook up some wires to my probe instead of just using the LED and doing it manually ;D
Looks very interesting :)
  •  9,200 9,200
Re: Probing Wizard
« Reply #2 on: January 06, 2013, 03:51:32 AM »
Looks good  8)
Re: Probing Wizard
« Reply #3 on: January 06, 2013, 12:40:27 PM »
Agreed, looks great-
Re: Probing Wizard
« Reply #4 on: January 06, 2013, 07:14:02 PM »
Thanks for the work TP....looks like a keeper to me.
Re: Probing Wizard
« Reply #5 on: January 06, 2013, 11:14:17 PM »
Can anyone think of ANY other probing routines that need to be covered ?
Re: Probing Wizard
« Reply #6 on: January 07, 2013, 04:58:22 AM »
Hi Terry,
For some of us who aren't entirely sure what each probing routine picture shows, maybe a brief description of each would help sort out what you already have in mind, and possibly what someone else may need/want?
Re: Probing Wizard
« Reply #7 on: January 07, 2013, 06:53:46 AM »
How about edge/wall probing routine like Stirlings program does that will follow around the perimeter of some shape and records the X&Y coordinates into CSV data? Then that CSV data can be imputed in for the 3D digitizing routine so it will only digitize within that shape to save time. Also something that will convert the CSV data generated to a G-code or STL file. Should I continue?  ;D
http://www.youtube.com/watch?v=9skopcbhurU
Jeff
Extensivly Re-worked/Re-designed/Modified Servo K2CNC KG-3925 and the Mini Laser Engraver
Re: Probing Wizard
« Reply #8 on: January 07, 2013, 03:57:57 PM »
THese are probing routines for 2.5d / mechanical work.
Stirling is working on a new improved version of the creepy crawler type 3d digitizing routine.
There are programs that already do all the rest(;-)
Re: Probing Wizard
« Reply #9 on: January 07, 2013, 04:31:36 PM »
Stirlings probing routine does not have a 4th axis option, so how about that? Lets say you have a figurine you want to 3D digitize all the way around with your rotary. How about styli ball diameter compensation for the 3D digitizing too? I see that is one of your routines.
Can you also have 3D digitizing routine retract to some distance from the last probe point instead of it doing a full retract in Z every time? Like this. http://www.youtube.com/watch?v=ZYJU1kwtzV4  It also saves it as a STL file which would be a plus too. I'm sorry if I am being a pain in the butt.
Thanks. Jeff
