Hello Guest it is April 24, 2024, 12:24:11 AM
Author Topic: Problem with Arcs  (Read 1825 times)
Offline viz
  •  17 17
Problem with Arcs
« on: January 04, 2013, 05:07:25 AM »
Hi, my tool diameter is D6mm.
If in program i make radius on corner R3, mach3 don't understand how to do it. Here is attached screen.
Green dots are the way my tool is going by.
If i make my corners with radius R3.1 everything works fine. Cam program is sheetcam.
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
Re: Problem with Arcs
« Reply #1 on: January 04, 2013, 09:04:03 AM »
you can not have a G02 or G03 with a radius of zero, if you tell Mach3 your tool is 2,999mm it will work.
