Hello Guest it is April 25, 2024, 08:05:05 AM
Author Topic: Pulse/Dir connection on Sanyo Denki  (Read 5442 times)
« on: January 30, 2007, 10:48:59 AM »
Hi
I have a question about connecting step/dir to my Sanyo Denki Bl Super amplifier.
It has position control, and can take either 2 pulse-trains or 1 pulse input and one direction input.
Has anyone ever connected this and run it under Mach software?
My main question is:
Do I need any kind of Breakoutboard, or do i connect the wires from my paralellport directly onto the amplifier?
Best reg
Cory
Re: Pulse/Dir connection on Sanyo Denki
« Reply #1 on: January 31, 2007, 06:47:54 AM »
It depends on the drive. The SD's I have seen have an internal buffer amp on the inputs. See if you can find the specs for input current. If it is much over 5mA a buffered BOB would be preferred.
Darek
« Reply #2 on: May 01, 2017, 01:10:09 PM »
Dear Cory..can you plzz post the dip switch setting of BL super amp.?
