Hello Guest it is April 25, 2024, 12:59:58 AM
Author Topic: Servo direction  (Read 5475 times)
Servo direction
« on: November 28, 2012, 11:09:21 AM »
Hello,
I have DSPMC V2. How i can give direction to inverter that have two digital inputs, one for each direction? I use Mach3. I know that Mach3 use pulse for step/dir but i have inverter with 2 digital inputs for direction and one analog 0-10V to control the speed of servomotor.
Thank you
Re: Servo direction
« Reply #1 on: November 30, 2012, 08:31:40 AM »
Re: Servo direction
« Reply #2 on: November 30, 2012, 06:28:51 PM »
What is the make and model of the drive/inverter that you are trying to run.
If it is a standard VFD, you use the analog output from the DSPMC to control the speed. You then assign 2 outputs from the DSPMC to give forward and reverse.
Mike
Re: Servo direction
« Reply #3 on: December 01, 2012, 07:17:49 AM »
I use ActiveCube inverter from Bonfiglioli (not step/dir controlled).
DSPMC need encoder for feedback if i use analog output and I don't have. I have closed loop servo - inverter with resolver.
I will try without encoder feedback.
