in the Cam Function Addons window NFSturn is listed. But under description it says "No Description", and under Author it says "UnKnown"
This can only mean the wizard is not properly installed, although I dont see how it could show up in the list of Function Names.
The wizard should be unzipped so that the NFSturn.set file is at C:\Mach3\Turnaddons\NFSturn\NFSturn.set There should be 6 files in this folder as well, Changelog.txt, GcodeEnd.tap, GcodeInit.tap, Init,m1s, NFStrun.set.def, and Threads.txt, as well as a folder called Bitmaps.
If teh Init.m1s is missing things dont get setup right in teh wizards. If either Gcode file or the Threads file is missing it will get an error, which should show in the Error window.
I really need to work on the code so that it tests for teh files and gives an error message in a box, not just on the error line.
