Hello
Guest
it is
April 18, 2024, 08:50:39 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Hot Rod Machining
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Hot Rod Machining (Read 5217 times)
Chaoticone
5,624
Precision Chaos
Hot Rod Machining
on:
January 25, 2007, 10:07:45 PM »
Does anyone know where I can get a 3d model of a 69 Camaro or a 65 Corvette that I can use to generate code?
Logged
If you could see the things I have in my head, you would be laughing too.
GaryB
108
Re: Hot Rod Machining
Reply #1 on:
January 26, 2007, 08:42:26 AM »
Have a Harley if that helps
actually you might try 3dcafe.com they have a bunch of freebie 3d's or Turbosquid.com
I"m sure if you do a google you will find a bunch more
Logged
Beckwith Decor Products
ArtCam Trainer
Onsrud & Custom CNC tooling Distributor
Wichita/Derby Kansas
http://www.beckwithdecor.com
ardor
130
Reply #2 on:
January 26, 2007, 07:18:37 PM »
How big is your table for probing?
Logged
There is no approved dental use for WD40
Chaoticone
5,624
Precision Chaos
Reply #3 on:
January 26, 2007, 07:52:46 PM »
Thanks Gary, I'll check those out.
Ardor, you are a mess. If you will send me the model. I will find a big enough table.
Logged
turmite
163
Reply #4 on:
January 30, 2007, 12:00:13 PM »
http://www.smcars.net/forums/index.php
Be prepared to spend way too much time there if you like cars. Most are modeled in 3ds but some are in Rhino.
Mike
ps spend time looking at the same model from different modelers. Like everything else.....some are better than others.
Logged
Chaoticone
5,624
Precision Chaos
Reply #5 on:
January 30, 2007, 12:42:12 PM »
Thanks Turmite,
Looks like a great site for this.
Logged
Yodawill2000
107
Reply #6 on:
February 02, 2007, 04:56:32 PM »
What are you getting yourself into Brett !!!
looks like fuuuun
Logged
Chaoticone
5,624
Precision Chaos
Reply #7 on:
February 02, 2007, 07:27:48 PM »
LOL....................Box wood derby at the Scout Hut.
Logged
Print
Pages:
1
Go Up
« previous
next »
