Hi David,
When I apply the background image it doesn't appear until I click on the backdrop
I'll look into it. I don't see that problem here.
If I set some DRO's on the screen, then decide to skin them, on selecting the skin and exiting the dialog,
the DRO jumps to the mouse and drags around.
I'll look into it. There is a Lock button on the toolbar. Use this to lock all the items
so they can't be moved when you want to select and edit properties.
The transparent dragging is really good - i like it a lot!
Yes, it helps to "see" the item while your dragging.
Where the screen explorer is on the right, is there a plan to have preview images there,
or even some text to describe each screen?
Absolutely. But right now, I am struggling to just get basic editing working.
Image handling is going to have to completely change and I have to finish
the MACH file format output generator.
Don't forget, if you set up an item (or items), you can drag them off your screen
and into the items palette (Tree) on the Left of the editor screen.
The editor will make copies and permanently store those for you for use on
other screens and/or projects.
For example, if you have a nice generic button or something like that,
you should add it to your palette. The palette displays your custom
items gray (normal items are always blue). Note : Make sure you
drop your item(s) into the right group.
Regards
Stan
