Hello Guest it is April 25, 2024, 03:18:15 PM
Author Topic: A new Huanyang VFD plugin  (Read 214865 times)
Re: A new Huanyang VFD plugin
« Reply #130 on: December 25, 2013, 04:02:44 PM »
I modified the 1.7.1 version of the plugin a bit so that it sets RTS high when sending, and otherwise keeps RTS low for receiving, so that it behaves with dummy RS485 converters.
It's a quick hack, and I'm not sure if royaumedeole would approve releasing this, but if there's an interest in this, I can link it.
« Reply #131 on: February 05, 2014, 06:42:58 PM »
Awesome plugin and glad there are people like you who put time into this stuff!  I got it working and love the added e-stop trigger features!  Issue I run into is I have to engage an e-stop and then reset it before I can engage the spindle a second time.  First time works like a champ, second time it does nothing until I hit reset and then reset again.
Thoughts?  Would noise cause this kind of behavior?
« Reply #132 on: February 05, 2014, 07:37:47 PM »
I think the issue I mentioned before is the same as yours. I was finding on the first run, the spindle button in mach3 flashes for a couple seconds, the spindle does nothing, then it goes to estop because it cant detect any spindle movement. But then when you un e-stop it and try again it runs flawlessly. It has never not worked on the second try. This sounds very similar to your issue, and my "first time running" might not even be the first time, it may actually be the second time like what you're experiencing.
Ill have to check again, but from what I recall I think the VFD "clicks" like it received a signal, but the motor doesnt move at all. Until, like you said, it e-stops and you clear the e-stop, then it runs flawlessly
Seb: Do you have any idea whats going on? Maybe a variable in the code isnt reset after the first successful run or something?
« Reply #133 on: February 07, 2014, 05:00:28 PM »
How did you modify, do you have the source code?
Nosmo
« Reply #134 on: February 25, 2014, 11:45:58 AM »
While setting up this plugin, I had a problem getting the motor to even run. I played with it all day, only to find out my spindle motor burnt up. Now I don't know if it was caused by the plugin or if it was on it's way out beforehand. The spindle ran fine before the plugin was installed. I installed the latest version, as well as the C++ file and driver for the usb rs485 adapter. After the plugin install, It recognized the settings from the VFD and showed up after the install. It took me a while before I realized I needed to set a speed in the box first before I tried to turn on the motor. Once I did that, it ran, but very erratic. After a few tries to get it to run faster, it just died.
Long story short, after taking apart the spindle motor, with plans to rewind it, I found out that the Chinese 1.5kw water cooled motor is not a four pole motor. The VFD comes preprogrammed for four poles. The motor I have is actually a two pole motor. Now I don't know if that makes any difference, but I thought I would mention it, so others can check their VFD for the right set up. The VFD comes preset for four poles and should only make the motor run half speed. Set for two poles will make it run twice as fast.
Right now, I have my motor all ready for the rewind. I just got my wire yesterday and will start turning soon. Just for those wondering, my motor is over three years old, but only has 10 hours or less on it.
Don
« Reply #135 on: February 25, 2014, 12:27:05 PM »
Another issue is that the min freq has to be set otherwise if trying to run lower rpm will burn the motor out, it lacks sufficient inductance at any lower frequency.
IIRC it is PD011.
N.
« Reply #136 on: March 11, 2014, 04:59:40 PM »
Is there a particular RS485 adapter that is recommended? I have one of those cheap black USB ones ( http://www.ebay.com/itm/331071937819?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 ) and Mach3 runs unstable with it. I will lose steps occasionally. It gets worse with higher kernel rates. It does not happen if I disconnect the USB adapter and operate the VFD manually. I was thinking about getting a RS232-RS485 adapter instead. Is this a good one? http://www.ebay.com/itm/190380830801
« Reply #137 on: March 11, 2014, 06:58:59 PM »
Maybe it's not the adapter after all. I don't know. Here's a video showing the difference between having the plugin disabled, and enabled. That's the only difference between the two parts of the video. http://youtu.be/wOzXPzTsmVE
« Reply #138 on: March 11, 2014, 11:45:39 PM »
Check this one out. I have been using this one since 10/2013 and have not had any problems at all with my VFD and spindle. Far better than the black junk one, it went in the trash.
You will need a cable, it uses the same cable that is on my Dell printer. It has about a 1/4" or 5/16" square plug on one end and USB on the other.
http://www.ebay.com/itm/KMTronic-USB-One-Relay-Controller-RS232-Serial-controlled-BOX-/271361447833?pt=LH_DefaultDomain_0&hash=item3f2e671799
« Last Edit: March 11, 2014, 11:49:18 PM by gene8522 »
« Reply #139 on: March 12, 2014, 12:22:10 AM »
