Hi I am new here hope someone can help . Btw I did a few searches and found a bunch of font size topics. Spent hours trying to figure it out still have no luck from what I see ( It is not a windows issue nor a screen resolution) , it must be in mach3 program setting or pos patch set up files because its only the font size in the program screen that i need to change smaller to fit the screen.
For some reason the Font is larger in that screen only exceeding the window. In the Mach3 program under con fig fonts ( all fonts default to 18 ) i tried to change code font to smaller font but it does not let you save a new font size???
I have a TAIG micro mill 2000LE with the original controller box I was sent these files with instructions .
Mach3mill.xml and MPS1024E.set into the main Mach 3 folder on the hard drive of your computer. When prompted replace the existing Mach3mill.xml. Next copy the file BackgroundToolpath3.jpg into the Mach 3 sub-directory Mach3\Bitmaps\Millbitmaps.
Every thing seems to be working find except the font size in the Program screen ONLY.Any ideas what to try next or how to fix font size in the program screen?
TIA
Kenny v
