Hello Guest it is March 28, 2024, 08:31:24 PM
Author Topic: NFS Wizards on Tormach  (Read 4678 times)
« on: October 26, 2012, 04:45:27 PM »
I put the latest Tormach version of Mach 3 on my PCNC yesterday, prior to that I copied and pasted the Wiz license to
the desktop, I then put it back in after the new install. The NFS wizards screen opens but I can't get past there?
Even with no license file they normally work but won't post code?
Will
Re: NFS Wizards on Tormach
« Reply #1 on: October 26, 2012, 05:17:15 PM »
What wizard version are you trying to run? If its not 2.86 then get it from this forum at http://www.machsupport.com/forum/index.php/topic,18321.0.html
I assume you mean the Continue button doesn't work. That button needs to open the material file, and it should find it even on a Tormach system- I fixed that several versions back.
I need to figure out how to use the error trap function in CB so I can display a decent error message. Ill try to work on that soon.
« Reply #2 on: October 27, 2012, 11:11:26 PM »
Yes that was it Ron, thanks for the help.
Will
« Reply #3 on: October 28, 2012, 10:52:56 AM »
DID you put it in the exact same directory as the old version or create a new copy in another directory?
Just a thought,(;-) TP
