Hello
Guest
it is
April 25, 2024, 02:13:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
rotary axis has stops moving
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: rotary axis has stops moving (Read 2931 times)
smithvac
3
on:
October 19, 2012, 06:31:47 PM »
Hi
I am a new user and I have a rotary axis (a) that seems to have a limit. I can go so far then it stops and only allows me to go the opposite direction.
What settings do I need to change to make it rotate indefinitely.
Any help would be appreciated.
Logged
BR549
6,965
Re: rotary axis has stops moving
Reply #1 on:
October 19, 2012, 07:31:03 PM »
Sounds like you may have a soft limit set for the A axis .
Logged
Carnoustie, Scotland
Reply #2 on:
October 20, 2012, 04:37:39 AM »
Yes as TP says you likely have the rotational; soft limits enabled, you will find that option on General Config page near the lower middle right section of that page.
Logged
smithvac
3
Reply #3 on:
October 20, 2012, 02:05:22 PM »
I will have a look
Logged
smithvac
3
Reply #4 on:
October 22, 2012, 11:02:41 AM »
Hi I turned off the rotational soft limits and restarted the software. It did't change.
Logged
Reply #5 on:
October 22, 2012, 03:40:57 PM »
Can you attach your xml and I will have a look.
Logged
Print
Pages:
1
Go Up
« previous
next »
