Hello Guest it is April 23, 2024, 09:58:53 PM
Author Topic: Unable to select font (VB editor)  (Read 4526 times)
« on: September 21, 2012, 05:54:55 PM »
Hello,
First, thanks Klaus for this nice soft !
I've a little problem:
When I edit VBscript from MachScreen, I get very small characters in the editor
I try to change it, but in the settings windows there is no fonts in the list and if I type manually a font size and/or a font name, it as no effect.
An idea of what I can do to solve this problem ?
(MachScreen 1.55 - Win XP pro SP3)
David
Re: Unable to select font (VB editor)
« Reply #1 on: September 22, 2012, 06:26:26 AM »
Hi David,
I wasn't able to reproduce your problem. I tried Win7 64bit German language and French language package and Win XP Sp3 German. It would be interesting, if other french users have the same problem. If you could give me your email address, I would send you a special version, to find the cause of this problem.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: September 22, 2012, 01:53:14 PM »
Hello klaus,
Today I just install Machscreen on an old PC for a friend  (with a brand new install of Xp Home ).
Same results for the font list that is empty, but the font used in the editor have a bigger size.
I try with English and German UI for Machscreen, and I get the same result. I know also another user that have same pb, but I can't remember if he use XP or 7.
This pb is not new in 1.55, I have it from a long time with older release.
I send my email by PM
David
