Hello Guest it is April 25, 2024, 02:06:33 PM
Author Topic: Outputs stay high  (Read 8066 times)
Offline rcrabb
  •  146 146
Outputs stay high
« on: January 18, 2007, 08:38:39 PM »
I just noticed that the output controlling my spindle stays high when you shut down mach. If I toggle the output high and shut down mach the output stays high. This may cause some safety concerns.
Ryan
Offline kookaburra
  •  56 56
  • Fussy? Yep! That's Me ;)
    • Akela Website
Re: Outputs stay high
« Reply #1 on: January 26, 2007, 06:19:22 PM »
Ryan,
I agree I have tested it and you are right I have also noticed that when Mach 3 recieves an e-stop from the pod, it does not pull the output lines down either, I will have this fixed as soon as I can contact Art. I won't bug him this weekend, but first thing monday I will.
Regards
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
"If you think you are under pressure - Try opening a sippy cup on an airoplane - 30,000ft in the air"
Greetings From Down Under
Dave Drain
Akela Noble Technologies Pty. Ltd.
