Mach can only put out a full pulse a minimum distance so whatever your steps per unit work out to is what you will have. The only way to make the resolution better is increase the steps er unit. Obviously the steps per unit are governed by the type of motors, microstepping of drives, ballscrew pitch, gearing etc so you cant just change the steps per unit, you would have to alter some of the aforementioned factors.
