Hello Guest it is April 26, 2024, 11:49:50 AM
Author Topic: Newfangled wizards for Mach4  (Read 20785 times)
Re: Newfangled wizards for Mach4
« Reply #20 on: February 26, 2013, 07:30:52 PM »
There is
Zrapid  ( cleance to move anywhere on the table)
Zclearance  (clearance to move inside of the current operation)
Ztop  ( Top of material)
Z0  ( Z point of origin 0.000)
Zstep (Zstep depth)
Zdepth ( final depth to an operation)
Just a thought, (;-) TP
« Reply #21 on: February 26, 2013, 07:43:01 PM »
Note that Clearance is not an absolute value, but is a distance measure. One example, when doing a multi-pass pocket it moves up the clearance distance above a cut for the rapid move back to the start for the next pass. Also on the start of a cut it moves down from the rapid height to the clearance distance above the Ztop of material.
All the other values are absolute values based on the current coordinate system.
« Reply #22 on: February 26, 2013, 09:58:33 PM »
Clearance AND step are incremental moves and the rest are absolute.
« Reply #23 on: February 27, 2013, 07:18:00 AM »
Yes,you are right, I forgot that one.
« Reply #24 on: February 27, 2013, 07:52:29 AM »
Lets close this topic and move over to the new section just for the Mill Wizards. http://www.machsupport.com/forum/index.php/board,92.0.html
If I can figure out how Ill write lock this topic.
