There's also the issue of wishing to define the last depth increment.
A pocket for instance where you'd like to specify the last pass depth.
.3 deep
.1 per step with last step .01 for a better finish.
would be -.1, then -.2, then -.29, then -.3
In other words, specify First past and Last pass and let the Wizard do the math.
Some of the other Wizards look this way.
Or would you just run another separate finish tool path ?
Russ
