Have a huge problem with the Vital DSPMC v2 and respond time of the feed override G01 and G00 rapid traverse.
The DSMP of Vital is for CAM users with 3-D lines (G01) and many small lines (G01) very, very dangerous.
If high feed driven in 3D so it's dangerous!
I have 2 Potentiometer on the machine. One Potentiometer is for G01 and one for G00.
If you want to reduce the feed override, so it's a long time to respond to the feed.
If you get a new part on the machine, the feed will appeal depending on the buffer size very delayed.
G00 is also delayed at the same time.
I have 3 controllers DSPMC v2 from Vital and all have the same problem.
The buffer must be set to minimum 10-15% if you run 2 million lines of G01 with F2000-5000 mm feed. Otherwise stutters the axes.
Depending on the buffer size, and the lengths of the G01 lines. The axes reduce the speeds at few millimeters up to centimeters.
Crash is programmed.
I have now several crashes with milling tools. Now it's too much
How did you solve this problem, the response time of the feed rate and even 3D-milling at high speed?
I think that this problem needs to be solved. By Industrie Maschines is it so.
The response time is directly.
If the problem cannot be resolved, I need to search for new controllers.
Does anyone have experience with other controllers?
Sorry for my language
Thanks for your help and greetings from Switzerland
Guido
