Hello Guest it is April 23, 2024, 02:50:23 PM
Author Topic: Did I wire my limit switches correctly?? See image  (Read 7419 times)
« on: August 14, 2012, 09:17:48 AM »
Not sure if I wired my limit switches correctly. I attached an image to look at but not sure if it posted.
Glen
Re: Did I wire my limit switches correctly?? See image
« Reply #1 on: August 14, 2012, 09:36:37 AM »
Hi Glen,
It's OK them being in series like that, but you didn't mention where are you wiring them to. Is it directly to the PP without a breakout board? If so then I think that the PP inputs are being pulled down normally anyway, so you'll need to connect the other side to 5VDC instead of the COM (which I assume is GND in your schematic)
« Reply #2 on: August 14, 2012, 11:01:37 AM »
Dan,
All I have is the the power supply hooked to a 4 axis driver board model (TB6560HQT4-V3) purchased from Ebay. What does PP stand for and do I need a breakout board. I can jog my motors but after I wired the limit switches they stopped working. Once I disconnected the limit switch I could again jog the motors. This prompted me to ask this question. I have another block of connectors labled; 5v (output), PU/CK (pulse), CW (direction) EN (enable) and GND (ground). Should I still connect to the 5v or GND?
Thanks so much!
« Reply #3 on: August 15, 2012, 03:55:05 AM »
Can you attach the driver manual or a link to one?
« Reply #4 on: August 15, 2012, 10:44:40 AM »
Yes, I attached a PDF of the manual.
« Reply #5 on: August 15, 2012, 03:39:59 PM »
They don't exactly provide this information in the manual, but based on their Active Low setting in Ports and Pins for the limits (on page 20) I think that the inputs are normally pulled high. Changing it to Active High (uncheck the Active Low box) should fix this.
« Reply #6 on: August 17, 2012, 09:06:32 AM »
I unchecked the active low box and still can't jog the motors. I checked all the switches and they are closed. Hummmm...
« Reply #7 on: August 17, 2012, 11:04:29 AM »
Go the the diagnostics page and see if the limits LEDs change state when you play with a switch.
« Reply #8 on: August 19, 2012, 02:02:50 PM »
On the Diagnostics only the M4++Limit LED is yellow. When I trigger any of the switches it turns off and nothing else is on. See attached pic.
« Reply #9 on: August 19, 2012, 05:03:05 PM »
Attach your xml and I will have a look.
