Hello Guest it is April 26, 2024, 09:12:25 AM
Author Topic: Z-axis problem on our drill  (Read 11025 times)
Re: Z-axis problem on our drill
« Reply #10 on: August 10, 2012, 05:26:07 PM »
Rich,
       We reloaded the software onto a new PC and the problem with skipping steps has been eliminated.  The g-code is now cutting the parts on the x and y axis's, and the z is mostly working except, on each pass the z raises slightly so by the end of the cut, the cutting tip is way up in the air.  It's as if the x axis on the mill is at about a 30% angle.  Is there a setting where I can tell mach 3 where '0' on the z axis is at more than one point of the cutting table?
« Reply #11 on: August 10, 2012, 07:51:44 PM »
Not that I know of.
You say that the problem of missing steps was corrected yet the Z is still not holding to position. ???
 How about swapping one of the other drives to run the Z and see if the problem is drive related.
« Reply #12 on: September 05, 2012, 08:27:42 PM »
I would thing that you have something loose in the mill, like a loose coupling from Z motor to the screw.
When you home the Z axis after that, what happen?
Just guessing.
Jeff
« Reply #13 on: September 05, 2012, 09:59:58 PM »
problem fixed.  turns out it was a bad controller board in our system.  put in a new one and the problem went away.  thanks for the help.
