Hello Guest it is April 26, 2024, 02:19:07 AM
Author Topic: Home position on screen  (Read 5441 times)
« on: August 05, 2012, 11:13:13 AM »
Hi Lads
As is the home position on the Mach3 tool path screen is bottom left , is it possible to change it to top right ?
Thanks Rob
Re: Home position on screen
« Reply #1 on: August 05, 2012, 11:19:56 AM »
I think you mean the Origin, as Home can be anywhere you want.
The only thing you can do is manually rotate it 180°. You can't change the coordinate system or the way it's displayed.
« Reply #2 on: August 05, 2012, 11:31:11 AM »
Hi Gerry
  I have a turret mill i am converting , and to have the screen origin match the machine home position" Visually "  means the table of the mill would be away from me and to the right , I was just wondering if it was possible to have   my machine home position ,table forward and to the left and the screen represent that .
Thanks Rob
« Reply #3 on: August 05, 2012, 12:17:57 PM »
Like this  :)
Rob
« Reply #4 on: August 05, 2012, 01:21:40 PM »
As I said, all you can do is click in the window and rotate it by hand. Mach3 doesn't allow anything else.
« Reply #5 on: August 05, 2012, 03:10:30 PM »
OK  , Thanks Gerry
Rob
