Hello Guest it is March 28, 2024, 06:54:11 AM
Author Topic: New to cnc and looking for help.  (Read 9846 times)
« on: August 02, 2012, 03:57:55 AM »
New to G Code and would like to ask if someone could convert a file for me for Mach 3
It is for an eye patch. I am blind in my right eye and wanted to do one.
Thanks in advance for any help.
Re: New to cnc and looking for help.
« Reply #1 on: August 02, 2012, 09:19:57 AM »
Best to just post the file and I am sure you will find some assistance.
« Reply #2 on: August 02, 2012, 03:10:16 PM »
For some reason it is really giving me a hard time posting anything. But I will keep trying.
« Last Edit: August 02, 2012, 03:11:52 PM by JGamble »
« Reply #3 on: August 02, 2012, 03:19:39 PM »
Here it is
« Reply #4 on: August 03, 2012, 09:24:04 AM »
Is this what your looking for?
Seems to me it should be somewhat convex in shape, unless you plan on shaping it after you cut it out.
Before I could create the code I'd need to know what tools you have available that would cut the slots and the outside shape.
« Last Edit: August 03, 2012, 09:27:49 AM by Ya-Nvr-No »
« Reply #5 on: August 03, 2012, 04:11:46 PM »
Hello
Yes that looks good. as for the tool bit, I have a few single flute spirial bits but I am not sure yet what bit will do the best as I haven't done anything in aluminum.
I was just gonna shape it after the cut so I could cut it out of flat stock.
Jim
« Reply #6 on: August 03, 2012, 04:16:56 PM »
Either way I still need some cutter sizes to create the profile path cuts
« Reply #7 on: August 03, 2012, 05:04:22 PM »
I wil be tryin a  1/16 helix single flute
« Reply #8 on: August 03, 2012, 05:34:48 PM »
May i suggest that you have a look in Members Doc's, End Mill Speeds and Feeds as to an approx spindle speed and feed that you will cut the
Al at. The gummy soft Al can be hard on small end mills.......just don't want you breaking them.   ;)You may want to say how thick your stock will be also.
« Reply #9 on: August 03, 2012, 05:54:39 PM »
Yes I'll do that, The stock will be 1/8" to 3/16th"
