Hello Guest it is April 20, 2024, 07:37:30 AM
Author Topic: create new tool- grooving tool-inscribed circle  (Read 6304 times)
« on: July 31, 2012, 04:34:12 AM »
Hello chaps.
Newbie to lazyturn and am trying to get my mind around tool creation
I am setting up a grooving tool to do the example .
firstly
How is the "inscribed circle" applied to a parting tool with a
3.5mm wide tip?
In the tool setup dialog what value must i puit in inscrided circle,
tip radius and flank cut depth?
secondly what is the significance of the size of the inscribed circle
and how is it used by the program ?
TIA
regards
fred
Re: create new tool- grooving tool-inscribed circle
« Reply #1 on: July 31, 2012, 06:54:12 AM »
I'll clarify later ....got to go
« Reply #2 on: August 04, 2012, 07:38:03 AM »
Hello Rich--  Have you had a chance to look at this topic yet
regards
fred
« Reply #3 on: August 04, 2012, 10:26:13 AM »
Fred,
How is the "inscribed circle" applied to a parting tool with a 3.5mm wide tip?
I will need to do some testing to see the affects of varying parameters and that takes time, hours not minutes.
I am going to guess that using tool tip radius and inscribed circle the same value and not ticking use use tool tip radius will
work but don't qoute me on that.
In the tool setup dialog what value must i puit in inscrided circle, tip radius and flank cut depth?
Each is defined in the manual starting on page 15.
what is the significance of the size of the inscribed circle and how is it used by the program ?
See attachment which corrects page 16 of the manual.
« Reply #4 on: August 04, 2012, 12:10:16 PM »
thank you rich--
that answers the question
Please send a opening key for the page so that it can be printed
many thanks
fred
« Reply #5 on: August 04, 2012, 06:45:52 PM »
Didn't know i had it locked so for now print the jpg.
