Hello Guest it is April 26, 2024, 06:48:15 AM
Author Topic: CorelDraw PLT to Gcode  (Read 23195 times)
« on: July 13, 2012, 12:54:29 PM »
I do most of my art & sign drawings on CorelDraw.  For some reason now when I convert them over to G-Code they show up on Mach3 as a 3-D drawing.  Which in turn makes my Z axis zero out then go sky high.
What am I doing wrong???
Also I changed them over to DXF files thinking that might do it but on SheetCam the drawing is all distorted.
Thanks for any help!!!
  •  9,200 9,200
Re: CorelDraw PLT to Gcode
« Reply #1 on: July 14, 2012, 08:10:14 AM »
Hi FlatCreek,
Perhaps some more details of exactly what you are doing may be helpful in resolving the issue.
I presume you are exporting the Corel drawing as a PLT file then loading this into LazyCam to create the necessary GCode toolpath ??
If so then perhaps the problem is within your LazyCam setup.
« Reply #2 on: July 14, 2012, 10:37:23 AM »
I am using Sheetcam for transfer into G-Code.
Thanks Tweakie!
  •  9,200 9,200
« Reply #3 on: July 14, 2012, 11:39:52 AM »
Hi FlatCreek,
Sounds as though the problem is in your SheetCam settings then.
Sorry I can't be of any help here as I have no knowledge of using SheetCam but there are many other forum members who use it all the time and I am sure they can help.
« Reply #4 on: July 14, 2012, 11:56:02 AM »
Thanks Tweakie, I really appreciate it!  I will check that out!
« Reply #5 on: July 15, 2012, 08:55:39 AM »
I use CorelDraw with Rojer screenset , it is perfect for Corel.
http://www.machsupport.com/forum/index.php/topic,5182.0.html
Usama
