Hello
Guest
it is
April 20, 2024, 02:30:21 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Mach Turn 3D Toolpath
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach Turn 3D Toolpath (Read 3116 times)
himpini
3
on:
July 02, 2012, 06:15:50 PM »
Hello, I am using Mach Turn in a Takisawa Lathe, I cant see in the toolpath screen the 3D screen likes shows the manual.
Can anyone help me with this??
Logged
Carnoustie, Scotland
Re: Mach Turn 3D Toolpath
Reply #1 on:
July 02, 2012, 06:23:38 PM »
Not sure whats in the manual but if you go to Config then Toolpath you can select "Show Lathe Object.
Its sometimes decent but other times not, especially if you have internal toolpaths.
For example heres one with external only then the same part with the internal machining also.
Logged
Overloaded
4,922
Reply #2 on:
July 02, 2012, 07:46:58 PM »
himpini,
Just wondering if you are referring to the isometric view ?
Like this : http://www.machsupport.com/forum/index.php/topic,5074.0.html
If so, it is gone.
Russ
Last Edit: July 02, 2012, 07:50:30 PM by Overloaded
Logged
Print
Pages:
1
Go Up
« previous
next »
