Hello Guest it is March 28, 2024, 05:56:57 PM
Author Topic: Galil DMC 21XX  (Read 2687 times)
Galil DMC 21XX
« on: June 23, 2012, 10:03:39 PM »
Hello Everyone,
I am currently having problems with my Home routine and slave axis using Galil DMC 21xx.
IF I use galil plugin version 4.4 the home sequence works fine, But i cannot get Axis to slave on the X Axis.
If t use Galil Plugin Version 4.5 which is I think the right plugin for this controller the slave axis works but home routine doesnt.
I hits the limit switch and stop and does nothing.
Anyone has the same problem? I would appreciate very much if you could help me with this problem. It might just be a mistake on my setup. Thank you .
« Last Edit: June 23, 2012, 10:08:31 PM by renatom »
Offline smurph
  •  1,544 1,544
Re: Galil DMC 21XX
« Reply #1 on: July 03, 2012, 01:32:11 PM »
Unfortunately, the gantry homing is not working correctly at this time.  So you are not alone.  :(  The problem is that neither Kenny nor I have a gantry machine to test on to get it working.
Steve
Re: Galil DMC 21XX
« Reply #2 on: July 03, 2012, 06:35:35 PM »
Hello Steve,
Thank you very much for your reply and Information regarding the Gantry problem on Galil DMC21XX. I have solve the problem by using each individual home inputs rather limits using them as home inputs. Thank you very much again.
Renato
