Hello Guest it is April 25, 2024, 03:41:15 AM
Author Topic: 3-Axis non-turret tool change with Mach3 Turn?  (Read 5773 times)
« on: June 17, 2012, 09:21:33 PM »
Hello All,
I'm retrofitting a Boxford Duet CNC lathe and I'm running into some challenges for how to set up the tool changer in Mach3 Turn.
I was hoping to use regular tool offsets but the tool changer for the Duet moves in the Y axis for the lathe, actual cutting of course still takes place in X-Z plane.
Is there a way to make Mach3 Turn display and record different Y-values for tool offsets or should I go about this with a Macro with info stored for each tool position?
I've added a link to a photo of the tool changer as well.
https://plus.google.com/u/0/photos/107441108435856955101/albums/5732712470253004977/5732712564851878018
Any guidance is greatly appreciated!
Thank you, Nathan
Offline Graham Waterworth
  •  2,673 2,673
  • Yorkshire Dales, England
Re: 3-Axis non-turret tool change with Mach3 Turn?
« Reply #1 on: June 19, 2012, 10:41:06 AM »
the link is not working.
use the Additional option to add a jpeg image and then we will be able to help you.
Graham
« Reply #2 on: June 19, 2012, 12:40:23 PM »
Here is a photo of the tool changer. It has 3 tool positions in front and 3 in the rear. Moving to each tool requires a linear vertical move that is not in the X-Z plane.
Boxford Duet 3-Axis non-turret tool change with Mach3 Turn?
« Reply #3 on: January 20, 2014, 07:18:25 PM »
Code: [Select]
M6 Start Code Below
toolpos1 = GetOemdro(1001)
toolpos2 = GetOemdro(1002)
toolpos3 = GetOemdro(1003)
toolpos4 = GetOemdro(1004)
toolpos5 = GetOemdro(1005)
toolpos6 = GetOemdro(1006)
toolnew = GetSelectedTool()
toolold = GetOemdro(824)
If (toolnew = 0)Or(toolnew = 0 ) Then
MsgBox (" invalid tool number !!!")
message(" invalid tool number !!!")
Call Code("M30")
end
End If
If (toolnew = toolold) Then
message("tool in use!")
end
end If
If (toolnew < 1)Or(toolnew >6 ) Then
SetCurrentTool(toolold)
Call Code("M30")
end
End If
message(" toolchange running !!")
If (toolnew = 1)then
Call Code("G0 G53 X105 Y4.5"&(toolpos1))
While ismoving()
Sleep 100
Wend
End If
If (toolnew = 2)then
Call Code("G0 G53 X105 Y34.5"&(toolpos2))
While ismoving()
Sleep 100
Wend
End If
If (toolnew = 3)then
Call Code("G0 G53 X105 Y64.5"&(toolpos3))
While ismoving()
Sleep 100
Wend
End If
If (toolnew = 4)then
Call Code("G0 G53 X15 Y64.5"&(toolpos4))
While ismoving()
Sleep 100
Wend
End If
If (toolnew = 5)then
Call Code("G0 G53 X15 Y34.5"&(toolpos5))
While ismoving()
Sleep 100
Wend
End If
If (toolnew = 6)then
Call Code("G0 G53 X15 Y4.5"&(toolpos6))
While ismoving()
Sleep 100
Wend
End If
SetCurrentTool( toolnew )
message("toolchange finished !")
end
Code: [Select]
M6 End Code Below
REM The default script here moves the tool back to m6start if any movement has occurred during the tool change..
x = GetToolChangeStart( 0 )
y = GetToolChangeStart( 1 )
z = GetToolChangeStart( 2 )
a = GetToolChangeStart( 3 )
b = GetToolChangeStart( 4 )
c = GetToolChangeStart( 5 )
if(IsSafeZ() = 1) Then
   SafeZ = GetSafeZ()
   if  SafeZ  > z then StraightTraverse x, y,SafeZ, a, b, c
      StraightFeed  x, y,  z  , a, b, c
else
Code"G00 X" & x & "Y" & y
end if
Here's the code I modified to run a Boxford Duet....It requires homing switches and I added a homing button on the lathe screenset for the Y axis.
It's an old topic but the code will no doubt help someone who google's for a Boxford Duet toolchange macro as it hurt my head a little fudging bit's of code from all over to get this working.
If you only buy one piece of software...make it Mach (dont forget the wizards too ;) )
« Reply #4 on: July 20, 2016, 05:12:45 AM »
Code: [Select]
M6 Start Code Below
Call Code("M30")
end
End If
end
end If
Call Code("M30")
end
End If
While ismoving()
Sleep 100
Wend
End If
While ismoving()
Sleep 100
Wend
End If
While ismoving()
Sleep 100
Wend
End If
While ismoving()
Sleep 100
Wend
End If
While ismoving()
Sleep 100
Wend
End If
While ismoving()
Sleep 100
Wend
End If
end
Code: [Select]
M6 End Code Below
   SafeZ = GetSafeZ()
else
end if
Hi Kipper, I've just bought a Duet (collecting this weekend) but have very limited experience with Mach3 yet. Are you still around on the forum? I hope so. Will return once I've had a good look round the Duet.
