Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 23, 2013, 03:22:36 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
Mach Discussion
Mach Screens
Screen designer tips and tutorials
OEM Code Function
Pages:
1
Go Down
« previous
next »
Author
Topic: OEM Code Function (Read 884 times)
Nitromuse
Active Member
Offline
OEM Code Function
on:
May 19, 2012, 12:13:26 PM »
Hello World,
I have recently changed over to a standard 1024.set from the OEM's original screen set. The Edit G-code button is wired to OEM Code Function 115 in the standard 1024.set but still brings up the previous version's function, which redirects to an option box with several choices. I want to go directly to edit the file in Notepad. Where do these functions reside, so that I can edit out the redirection?
Logged
Klaus1311
Active Member
Offline
Re: OEM Code Function
Reply #1 on:
May 19, 2012, 04:23:19 PM »
Hello,
I assume you are using MachScreen. Could it be, MachScreen is set in multiple selection mode? If so click the button line to select the button, or change to single selection mode by hitting the second icon from the right in the toolbar. Once the button is selected you can set the Function code in the property dialog box. In order to load the changed set file in Mach3 you have to save your screen in MachScreen.
Klaus
Logged
Nitromuse
Active Member
Offline
Reply #2 on:
May 19, 2012, 05:05:02 PM »
I'm using Screen4, accessing the button and setting it's function code is straight forward, I can do that. The problem is that the OEM function code 115 takes me to a redirect, rather than directly to Notepad to edit the file. How do I edit the function called by this code so I can take the redirection part out of it?
Thanks so much for your help.
Logged
ger21
Global Moderator
Offline
Reply #3 on:
May 19, 2012, 07:08:31 PM »
In General Config, is your G-code editor set to use Notepad? If the button is set to use OEM Code 115, then Notepad should open. I can't think of any other reason why it wouldn't work.
Logged
http://home.comcast.net/~cncwoodworker/2010.html
Nitromuse
Active Member
Offline
Reply #4 on:
May 20, 2012, 06:50:14 AM »
Thanks Gerry, that was it. I was trying to make it too difficult.
Logged
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
G-Code, CAD, and CAM
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
Third party software and hardware support forums.
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
