Hello Guest it is April 20, 2024, 06:49:06 AM
Author Topic: Newfangled wizards.  (Read 3744 times)
Newfangled wizards.
« on: May 10, 2012, 11:48:26 AM »
I have been using these Wizards for some time and for the most part, they are a great way to create a part without the use of a dedicated CAD/CAM. What I would like to see is the option to delete any operation that you have created using the Wizards. As it stands now the only option that you have is to delete the last operation that you have created. If you are developing a part using the Wizards and you want to refine a certain feature of the part you have to delete the previous operation until you get to the feature that you want and then edit the parameters in the specific Wizard. It would make much more sense and much less work if you could select the Wizard you want to delete instead of scrolling back and deleting each Wizard in your program/part/g-code.
Re: Newfangled wizards.
« Reply #1 on: May 19, 2012, 05:40:12 AM »
You would be better to post this in the NewFangled Wizards section of the forum.
http://www.machsupport.com/forum/index.php/board,3.0.html
