Hello Guest it is April 26, 2024, 10:55:23 AM
Author Topic: DSPMC and ESTUN  (Read 4768 times)
DSPMC and ESTUN
« on: May 04, 2012, 07:38:17 AM »
Hello all,
It's been a while since my last post here. I have upgraded my machine to newer drives and motors (the older ones just didn't perform well) and I have done a lot of changes to machine. I have some problem about connecting. Where on DSPMC can I connect pin 18/36 which can be found on page 40 in the manual?
Peter
Re: DSPMC and ESTUN
« Reply #1 on: May 04, 2012, 09:46:05 AM »
Those wires appear to be the encoder ground or 0v. On the encoder breakout board there are the connections for the a, b and z plus thier complements. Next to hem are the ground or 0v volt connections. I don't have the manual handy so I can't give you the pin numbers.
Mike
Re: DSPMC and ESTUN
« Reply #2 on: May 04, 2012, 10:51:51 AM »
Thanks Mike for helping me. Are those ground pins on J6 and J7 the same as on J2 port? I have all connections done without boards (exept J4 board) so I don't have a spare cable left. I was thinking to connect them to ground cables on J2 port. Will that be ok?
Peter
Re: DSPMC and ESTUN
« Reply #3 on: May 05, 2012, 07:53:42 AM »
I am not sure and that your best bet would be to get Rufi to chime in. IIRC some of the grounds are interconnected internally but as I said I am not sure about the encoder grounds.
Mike.
P.S. Glad to help.
