Hello Guest it is May 10, 2024, 09:29:05 PM
Author Topic: Mach 3 setup with Pulse engine  (Read 15342 times)
Offline txpto
  •  26 26
Re: Mach 3 setup with Pulse engine
« Reply #10 on: April 26, 2012, 02:38:54 PM »
seldom I was in the same problem.
the solution was eliminate noise in VCC power supply of the motor controller.
USB connection between pc and pokeys fall when motor start chopper.
With and oscilloscope see signal vcc 5v and 24v of inverter... noise noise and more noise.
Separate via optocuplers step and dir and independent power supply and all ok.
Is my experience.
Enviado desde mi Transformer Prime TF201 usando Tapatalk 2
