Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 20, 2013, 02:43:39 PM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
Third party software and hardware support forums.
PoKeys
(Moderator:
NeoTO
Mach 3 setup with Pulse engine
Pages:
1
2
Go Down
« previous
next »
Author
Topic: Mach 3 setup with Pulse engine (Read 1625 times)
Seldom
Active Member
Offline
on:
April 24, 2012, 02:01:56 AM »
Guys, help.... i must be missing something easy but i can not get it to work.
- pokeys hooked up to drivers and new firmware, connection lan network
- mach 3 latest plugin and pulse engine set up properly including activation code
- motors run using the pokeys software directly.....but not in mach 3 ...?
Mach 3 setup of motor to Port 10 pin 38 and 46.
It seems that mach 3 does not recognizes the port 10, but this was the way the usb version was recognised.
jogging is not possible.
What am i missing?
Seldom
Logged
NeoTO
Active Member
Offline
Re: Mach 3 setup with Pulse engine
Reply #1 on:
April 24, 2012, 03:45:01 AM »
Hi, Seldom
You don't have to set any pins in Mach3! You just have to have axes X, Y and Z enabled in Mach3 setup (which is by default).
Did you follow the instructions in the manual - did Mach3 show that external motion controller was detected? Did you setup your PoKeys device in the plugin settings?
Matevž
Logged
www.poscope.com
home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Seldom
Active Member
Offline
Reply #2 on:
April 24, 2012, 05:45:42 AM »
Neo, thanks for your reply;
yes - pokeys device setup through the plugin > config restarted
yes - external motion controller popup came up and ive selected pokeys
In the pulse engine manual it than states motor config > as normal,
... so i assumed you have to select Ports/pins > and enable x,y, and selects port (10) and pins (38,46) in the Mach 3 menu...
i tried to do a clean new installation and start al over, but it seems hard to get rid of all settings files.
Logged
Seldom
Active Member
Offline
Reply #3 on:
April 24, 2012, 02:44:04 PM »
re-installed everything, but still nothing, pokeys is not communicating with mach 3.
I already reset pokeys...but somehow i never get back to where i have to fill out the activation code etc.... somewhere pokeys stores the setup files but i cant find it.
is the old mach3 plugin for the 56E still available, so i can test if that still works for the in-outputs...
Logged
txpto
Active Member
Offline
Reply #4 on:
April 24, 2012, 03:14:14 PM »
you have connected ESTOP pin to pokeys ? I think that is pin 52 ....
Enviado desde mi Transformer Prime TF201 usando Tapatalk 2
Logged
Seldom
Active Member
Offline
Reply #5 on:
April 24, 2012, 03:27:52 PM »
yep pin 52 is connected to gnd.
the strange thing is that the motors run using the pokeys software but in mach-3 jogging is not possible.
hmmm
Logged
txpto
Active Member
Offline
Reply #6 on:
April 24, 2012, 03:50:56 PM »
Have you got and oscilloscope ?
Can you see data/step signals with and osciloscope ?
is possible that signals are very fast and no understand by motor controller ?
Logged
Seldom
Active Member
Offline
Reply #7 on:
April 24, 2012, 04:02:43 PM »
Yes, i have a scope and i will try,
However in the mach-3 screen the axes coordinates to not change, they simply do not react to the jogging command from the keyboard,(If i switch to LPT port device this works fine)
Question: When you disconnect the pin 52 while jogging do you get any notice on your screen, like the E-stop or something? .....Because nothing happens on mine. So i suspect it's a communication thing.
Logged
NeoTO
Active Member
Offline
Reply #8 on:
April 25, 2012, 12:18:33 AM »
Well, it may really be a communication problem. Try increasing the timeout value in PoKeys configuration from 3 seconds to 30 seconds.
Secondly, do not run PoKeys software in parallel with Mach3.
When the emergency switch is pressed (52 is released from GND), the plugin puts Mach3 in Emergency mode and the big red button starts flashing.
Logged
www.poscope.com
Seldom
Active Member
Offline
Reply #9 on:
April 25, 2012, 03:16:48 PM »
it works... great. I have increased the time out, and again looked closely at the ip setting, made them fixed and it works like a clock.
Thanks for the support...we keep enjoying mach, and pokeys
Logged
Pages:
1
2
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
G-Code, CAD, and CAM
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
