Hello Guest it is April 26, 2024, 11:28:20 PM
Author Topic: Code error - help  (Read 4843 times)
Code error - help
« on: April 15, 2012, 09:55:55 AM »
Hi to the forum.
I am new both to the forum and to CAD-CAM. Trying to work my way through the vagaries of Lazyturn. I have produced the paths (x2) for a simple handle as a test piece. PP`d to a .tap file which I can read in notepad.(Attached)  - All seems well until I load into Mach 3 Turn. A default line reports "Bad format unsigned integerLine 2"
 Expect I am doing something fundamentally wrong, but have spent a lot of time fault finding to no avail. - Could anyone explain the fault for me please.
Re: Code error - help
« Reply #1 on: April 15, 2012, 12:03:13 PM »
When you hit the Post Code button, you get a Code Prolog box.
Any comments in there will be posted and must be in (  )'s or it will trow an error.
Or, you can leave the box empty.
Nice looking handle  :).
Russ
« Reply #2 on: April 16, 2012, 01:07:40 AM »
 Russ
Thanks!  That cracked it.
Spent a lot of time " not seeing what I was looking at !!!"
Rod
