Hello Guest it is April 26, 2024, 08:18:40 PM
Author Topic: EMCOTURN 140 Lathe conversion  (Read 13291 times)
Offline tpmx
  •  11 11
« on: April 14, 2012, 07:40:50 PM »
I just started a retrofit on an EMCOTURN 140 lathe.
I sold the original control in favor of running this lathe from Mach3
I am going with a VFD/3 phase motor for the spindle,850 oz/in servos with encoders for x & z  axis.
I have pretty much everything purchased from CNC4PC.
I have the enclosure constructed and mounted on the machine.
The spindle motor adapter plate and pulley adapter are made and the motor is mounted on the lathe and a quick test has been run just to check out the VFD and motor combo,
I have the demo version of Mach installed on the touch screen monitor.
I am just starting to mount the power supply,VFD,computer motherboard and c32 board plus 320x geckos and wanted to check on opinions
of having this all in the same inclosure.
I have enough room to neatly mount everything but want to know if I should be concerned of interference from the power supply or VFD to the servo power lines or with the encoders.
Here is a list of parts I have to work with
Hitachi X200 VFD
72v-20 amp power supply
850 oz.in servos with encoders
320x geckos
C32 CNC4PC board
Spindle index pulse board
Also am adding a second PCI parallel port in the pc to handle a rotary MPG and axis selection/resolution board
I would appreciate any input before I get into any trouble
I have done a cnc conversion on a 3-1 lathe/mill but with steppers
and built a cnc router also with geckos and steppers but these were simple compared to what I am doing now so
I am uncertain as to what to look out for
Thanks in advance
Re: EMCOTURN 140 Lathe conversion
« Reply #1 on: May 04, 2012, 07:00:33 AM »
First, which control did you have and where did you sell it and how much did you get out of it?
Secondly, you sold the spindle drive/motor? This was a pretty robust DC motor with encoder on it. Though I believe it required 380v to run. I have a 240 on the way which I believe is built on the same iron as your machine, but with full enclosure and hydraulic Collet closer and hydraulic tailstock. I was planning on going servos. My original control has a missing board and keyboard. Hope to part the rest out to get a few bucks for the retrofit.
Please post pictures of your machine and progress on your conversion.
Yes, I believe you can mount the power supply to one side of the cabinet and your electronics on the other. Done all the time in industrial controls. I suppose much depends on your cabinet. How about some pictures of your cabinet with your components sitting in there for us to see?
Marty
Mesa, AZ
Offline tpmx
  •  11 11
« Reply #2 on: May 04, 2012, 08:22:43 AM »
Marty
Thanks for the response
I will get some pics up soon as i ca
Offline tpmx
  •  11 11
« Reply #3 on: May 04, 2012, 08:30:20 AM »
Offline tpmx
  •  11 11
« Reply #4 on: May 05, 2012, 07:39:07 AM »
Here is a pic of the new enclosure so far.
I will get some more of the inside uploaded
https://picasaweb.google.com/115381577093850937925/May52012#5739011493139738274
« Last Edit: May 05, 2012, 07:50:28 AM by tpmx »
Offline tpmx
  •  11 11
« Reply #5 on: May 05, 2012, 06:54:37 PM »
been playing around on here awhile and dont seem to be able to get a picture to show right on my post.
Can someone guide me along on this?
« Last Edit: May 05, 2012, 06:57:02 PM by tpmx »
« Reply #6 on: March 16, 2014, 09:53:14 AM »
I can't seem to find this post in the mach forums, but since you've already done it I have the same questions as I'm working on a emco mill conversion. Did you have any problems with the motherboard mounted in the same cabinet as the servo drives and the vfd? cwalker1960@gmail.com
Offline tpmx
  •  11 11
« Reply #7 on: March 16, 2014, 11:54:36 AM »
I havent had time to spend on this project and am probably going to list it on Ebay.
I would relly like to finish it but I dont see it happening
Too many projects not enough time
« Reply #8 on: March 16, 2014, 12:13:18 PM »
Hey tpmx, where are you located ?
(pm if necessary)
Russ
Offline tpmx
  •  11 11
« Reply #9 on: March 16, 2014, 01:48:50 PM »
I am in Ohio
