Hello Guest it is April 18, 2024, 07:57:33 PM
Author Topic: Mach3 OPC server for SCADA application  (Read 2714 times)
« on: April 03, 2012, 06:06:45 PM »
Good evening,
Does anyone know which OPC server I can use to connect to Mach3?
I tried to connect Mach3 to my SCADA solution through the Modbus Serial RTU (Connecting 2 PC's with a null modem) and Mach Brains, but was unsuccessful.
I am using Movicon11.3 software to create the SCADA solution.
Thank you in advance for the assistance.
Tremaine
Re: Mach3 OPC server for SCADA application
« Reply #1 on: June 14, 2017, 07:57:42 AM »
Were you able to find a solution for this? Thank you.
