Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 20, 2013, 01:30:42 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
M98 to make multiple different parts on the same sheet.
Pages:
1
Go Down
« previous
next »
Author
Topic: M98 to make multiple different parts on the same sheet. (Read 472 times)
Your_Lordship
Active Member
Offline
on:
April 01, 2012, 11:30:36 AM »
Does anybody have an M98 guide? I found out the hard way, for example, that the (external file) subroutine doesn't belong in the same directory as the calling code, but in the MACH3/subroutines directory. Also, I figured out external subroutines don't work if there isn't an invisible carriage return after the M99 in the called routine. Now I can call up the SAME subroutine (cuts one part) and use M52 to duplicate it 10 times at different parts of the sheet. I can repeat this with a different part on a different sheet. As long as all the parts are the same, no problem. But if I call several routines for several different parts on the same sheet, the whole thing gets messed up. Parts beyond the first part show a tool path with those nasty large loops (not circles) for G2 arcs which suggest that the absolule coordinates have been wrongly set with G90.1. All the parts are using the same absolute coordinates and all the parts are similar. What could cause a subroutine to be somehow corrupted by running a prior subroutine?
Logged
BR549
Active Member
Offline
Re: M98 to make multiple different parts on the same sheet.
Reply #1 on:
April 01, 2012, 12:21:07 PM »
Are you using tool comp in any of your files?? Can you post an example of a complete program that fails?
Logged
Your_Lordship
Active Member
Offline
Reply #2 on:
April 01, 2012, 01:32:04 PM »
Yes, I have cutter radius compenstation in each of the subroutine files. I switch it off again with G40 when the routine returns, else G52 will not work. The first two calls to the same subroutine are fine, but the call to the next one has those funny arcs in it. Thanks for helping!
Calling program first:
% cut full sheet
G17 (cancel tool length offset)
G80 (cancel motion mode)
G50 (reset all scale vectors to 1.0)
G49 (cancel tool length offset)
G40 (cancel cutter radius compensation)
G90 (set absolute distance mode)
G21 (set units to mm)
G40 (cancel cutter offset)
G52 X0 Y0
% G54 (apply zero point offset)
G0 Z6
% cut first frame
M98 (front_frame.txt)
G40
G52 X80
G40
G52 X0 Y30
M98 (rear_frame.txt)
M30 (stop and rewind)
front_frame.txt:
G0 Z10
F100
% cut bolt slots
G0 X-20.3 Y15
G1 Z0
G1 X-20.5 Y9
G0 Z6
G0 X20.3 Y15
G1 Z0
G1 X20.5 Y9
G0 Z6
% cut holes
F25
G0 X24 Y-4
G1 Z-.1
G0 Z6
G0 X-24 Y-4
G1 Z-.1
G0 Z6
% cut outline
G0 X0 Y10 (go to lead-in position)
G41 P1.59 (apply cutter offset)
F100
G1 Z0
G1 X0 Y6 (start cut at bottom of V)
G1 X20 Y20 (cut right side of V)
G1 X22 Y20 (cut short flat top)
G0 Z0.5 (leave cling-on of 0.5mm)
G2 X24 Y18 R2.5 (top right rounded corner)
G1 Z0
G1 X28 Y0 (right edge to zero mark)
G1 X30 Y-8 (continuation of right edge)
G2 X28 Y-10 R2 (rounded lower right corner)
G1 X6 Y-6
G1 X-6 Y-6
G1 X-28 Y-10
G2 X-30 Y-8 R2 (rounded left corner)
G1 X-28 Y0 (left edge to zero mark)
G1 X-24 Y18 (left edge to top)
G0 Z0.5
G2 X-22 Y20 R2.5 (rounded top left)
G1 Z0
G1 X-20 Y20 (short flat top left)
G1 X0 Y6
G1 X2 Y7.4
G0 Z10
M99
rear_frame.txt:
G0 Z10
% Rear frame
F100
% cut clip slot
G0 X28.5 Y22
G1 Z0
G1 X28.5 Y14
G1 X31.5 Y14
G1 X31.5 Y22
G0 Z6
% cut outline
G0 X-4 Y-4
G1 Z0
G1 X0 Y4
G1 X10 Y27
G2 X14 Y28 R2.5
G1 X30 Y18
G1 X46 Y28
G2 X50 Y27 R2.5
G1 X60 Y4
G2 X58 Y2 R1.7
G1 X36 Y6.8
G1 X24 Y6.8
G1 X2 Y2
F25
G0 Z0.2
G2 X0 Y4 R1.7
G1 X0 Y4
G0 Z10
M99
Logged
BR549
Active Member
Offline
Reply #3 on:
April 01, 2012, 07:14:46 PM »
AH that part of toolcomp and SUBs is broken.
If you want it to work you would need to program the subs WITHOUT ToolComp. Then it will run OK.
BUT NOT with tool comp active beyond the first nested loop.
AND it is NOT going to be fixed in MAch3, Before you ask.(;-)
Logged
Your_Lordship
Active Member
Offline
Reply #4 on:
April 01, 2012, 11:34:59 PM »
OK. Well I least I won't spend further hours wrackjng my brain to figure out what I did wrong. Thanks.
Logged
DSLICKER
Active Member
Offline
Reply #5 on:
October 02, 2012, 02:47:56 AM »
i don't know i think it could work did you try to put the g40 in the sub program before the m99 instead of the main program before the g52 also call a g90 and a g90.1 in the sub
you could try a code like this but i use g10 line
IF YOU WANT TO DO A MULTI FIXTURE PROGRAM YOU COULD TRY THIS
O0001
#101=1(tool number)
#102=-.02(TAPPER BLOCK)
G90
G10 L2 P1 X-10. Y-10. Z-10.(G54 WORK OFFSET)
G10 L2 P2 X-10. Y-11. Z-10.(G55 WORK OFFSET)
G10 L2 P3 X-10. Y-12. Z-10.(G56 WORK OFFSET)
T#101 M6
M0
#1=54(STARTING OFFSET)
G0 G90 G#1 X0.5 Y0. S1200 M3
G43 H#101 D#101 Z1.
G0 Z0.1
M98 P0002 L3 (HOW MANY TIMES IT TAKES YOU TO GET TO FINAL OFFSET)
G0 Z10.
M30
O0002
G0 G90 G90.1 G#1 X0.5 Y0. S1200 M3
G0 Z0.1
g1 z-.1
G1 X5. Z[-.1+#102] F20.(TAPPER BLOCK)
G0 Z.1
#1=[#1+1](CURENT OFFSET PLUS 1)
M99
Logged
Pages:
1
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Mach SDK plugin questions and answers.
===> Finished Plugins for Download
=> VB and the development of wizards
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Screen designer tips and tutorials
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> Machscreen Screen Designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
=> Show"N"Tell ( What you have made with your CNC machine.)
=> Building or Buying a Wood routing table.. Beginnners guide..
=> Show"N"Tell ( Your Machines)
=> G-Code, CAD, and CAM discussions
=> LazyCam (Beta)
Third party software and hardware support forums.
=> LazyTurn
=> GearoticMotion Preliminary testing
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Third party software and hardware support forums.
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
=> Promote and discuss your product
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
=> Forum suggestions and report forum problems.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
